1. Join the Community!
Sold Built 1991 GSX Auto
Posted by Kapok6, Dec 5, 2019
Please Support STM Tuned
Please Support Feal Suspension
  1. Kapok6
    Kapok6 Proven Member
    1,230
    257
    Joined Aug 10, 2004
    Fort Worth, Texas
    1991 GSX Auto (I am 3rd owner; previous 2 were old men).
    Body has about 130,000mi. if that.
    Engine is Curt Brown Block and Head (Wiseco HD's, Manley TT Rods, blah blah blah-about 600mi on motor).
    GSC S2's
    Adjustable cam gears
    Jay Racing Alt relocation
    Sheepey Topmount divided T4 Manifold
    Custom exhaust with SS downpipe and aluminum from the DP back to an Apex Muffler
    N/T T-body
    BW S362 SX-E
    2100CC Injectors
    WereWolf Tuning on stock ECU from DS-Map
    Precision FMIC
    Rebuilt Auto trans with a couple thousand miles on it. Kiggly front clutches, alto red end clutches
    Higher stall converter (believe it's an old IPT re-stall)
    4 bolt rear end
    GC Coilovers on Koni Yellow shocks
    Enkei RS-5 Wheels
    Dry Nitrous system hooked up for help stalling up on the line if needed
    Forced Four Shift box
    Dynatek Arc-2 ignition
    Front bumper cover is from a previous car, but I have the unhacked stock bumper as well.
    Paint is original
    A/C removed
    Depowered steering rack
    Power windows and seatbelts work
    Car is on low boost (20-21psi right now). Years ago on smaller turbo and smaller cams car trapped 130.75mph in the 1/4 at 28-29psi.
    Also coming with the car would be:
    Rolling 1990 GSX Shell with title
    about 10yrs of spare collected parts like wiring harnesses, relays, blah blah blah. I have totes of stuff.
    one or two gas tanks
    like 4 Auto AWD transmissions (I have never run them, I got them in case I needed them in the future)
    like 3-4 transfer cases
    Spare restalled converter
    A few 6 bolt blocks with cranks (one being the original block/crank)
    4 spare 2g head cores
    1 complete 2g head minus camshafts. (was the head the car trapped 130.75mph on; has SS valves, MAP Springs/evo retainers)
    Spare auto AWD 4 bolt rear end
    Tons of stock gaskets, bushings, seals, etc
    New never used Magnafuel 4303 Pump
    New Aeromotive AFPR
    Various -AN fittings
    Never used Magnafuel 4303 external fuel pump
    Bunch of stuff i'm forgetting
    $8500 takes the car, $10k takes everything.
    Video of car running
    IMG_20180830_183828.jpg IMG_20180830_183843.jpg IMG_20180830_183857.jpg IMG_20180830_183905.jpg
    Kapok6
    Street Build 2K  0
    1991 Mitsubishi Eclipse GSX
    11.3 @ 130.75 · 1G DSM
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
