dlamontia
- 0
- Sep 21, 2009
omaha,
Nebraska
Edit: hey guys just had shoulder surgery can't do any of the minor repairs this is your chance. Best offer or trade takes it open to any and all offers for trade or cash. Thanks again.
Asking/Offering Price: 6k obo, also trades welcome
Email Address/Phone Number (optional): 402-885-1777
Item Description: Built 1991 Mitsubish Eclipse FWD
Year:1991
Make: Mitsubishi
Model: Eclipse
Mileage: 92,000 body 1400 motor
Title Status: Clean, my name
Transmission: Bulit TRE FWD LSD
Fully built 1991 eclipse GST I have owned this car since 2003
(Pictures dont do it justice)
*Color: Exterior Black/ Interior Black and Grey
*Mile on Body 92k
*Miles on motor: 1,400 brake in only on a mild tune
*This dsm has huge potential
Head:
All machine work sent out to have properly CNC machined by
Clear Water Cylinder head in
Clearwater Florida.
Intake side ported to exact specs to match the intake runners
Exhaust side ported and polished to exact specs to match the
exhaust header manifold
Five angle valve job
APR head stud kit
MLS Performance Copper head gasket with built in o-rings rated
at 1200hp
SS Manley 4G63 exhaust and intake valves
SBI Bronze intake and exhaust valve guides
SBR DSM High Performance valve stem seals, set of 16
Manley Dual Spring and Titanium Retainers
Manley Titanium Valve Keepers set of 16
Comp true competition 101/400 camshafts
Unorthodox Racing Adjustable Cam Gears
Block:
All machine work, balance and assembly was done locally by
the same machine shop referred by 3Dmotorsports
Wiseco HD 8.5:1 - 6 Bolt Pistons 86.5mm
Eagle 4G63 connecting rods
ARP Rod Bolt kit
ACL Race series main and rod bearings
Balance shaft eliminator kit
Block Coated Black
Fuel:
Walbro 255 in tank pump
SBR 8an braded stainless pump to rail and return (complete kit)
with all black 8an SBR push lock fittings
Black AEM high flow fuel rail
Black FUELAB FPR
Black FUELAB high flow fuel filter
Liquid filled FPG
Precision Turbo 680cc Low Impedance ball and seat fuel
injectors
Intake:
Sheet metal Magnus Intake Manifold with magnus heat barrier
gasket
Black 75mm billet throttle body
Bar & Plate Intercooler Core size: 25"x8"x3.5" 2.5" Inlet &
Outlet
Inner cooler 3.5in core with 2.5in aluminum pipe short route all
black silicon couplings
3" Black Dejon DSM Curved Intake Pipe 2G MAS on 1G Car 2g
mas conversion with easy to remove pig tail adaptor
Crushed 1g bov with Atmospheric blow off
Turbo and Exhaust:
DNP tubular 4-1 header manifold with external waste gate
Tial 40mm external waste gate with 2" atmospheric dump
Billet PTE 6262 turbo charge - HP Rating: 700+Exclusive CEA
(Competition Engineered
Aerodynamics) compressor wheel machined from
a 2618-aluminum forging Higher efficiency and faster transient
response for maximum power and performance 62mm inducer
compressor wheel
SBR 6an oil feed and return lines stainless braded with black
6an push lock fitting
3'-3.5 custom stainless exhaust made by sublime speed
technology. No Cat
Drivetrain:
TRE Stage 3 race transmission with quaifes LSD
Aluminum shifter bushings
ACT 3200 pound pressure plate
ACT 3200 max clutch kit
Others
Brand new oem oil pump
All new oem pulleys and tensioners
New oem water pump
Gates Racing Kevlar racing timing belt
Hallman Pro Black Boost Controller also have a
turbo xs duel stage
DSM Link
Coil pack relocated to where AC compressor was
Duel Slim line fans
Carbon fiber spark plug cover
Polyurethane motor mounts
Oem style Carbon fiber hood
battery relocated to trunk with vented
enclosure
The Bad
Needs new front control arms cant finish the tune until those are
on and allignment is done
will need slicks for front
flex pipe is leaking
spolier and headliner are out might carbon wrap them but havent
gotten around to it yet
some interior is out have all just was gutting some of the wiring
that was done by orginal owner.
Looking to trade for: AWD, 4x4 trucks , Hondas, Suvs ext i do
not want another project. Really woukd like a lifted truck
Thank you,
I have tried to be as descriptive as possible and list everything that has been done to this car. Please feel free to message, call or text with any questions. Also Chad from 3D Motorsports completed this build and is very familiar with this car. Would be glad to show anyone interested.
Year:1991
Make: Mitsubishi
Model: Eclipse
*Mile on Body 92k
Head:
Clearwater Florida.
APR head stud kit
at 1200hp
Block:
ARP Rod Bolt kit
Block Coated Black
Fuel:
Black FUELAB FPR
Liquid filled FPG
injectors
Intake:
gasket
Outlet
Turbo and Exhaust:
compressor wheel
technology. No Cat
Drivetrain:
Others
New oem water pump
turbo xs duel stage
DSM Link
Duel Slim line fans
enclosure
The Bad
Thank you,
