blewbyu
- 54
- 0
- May 14, 2002
Homosassa_Florida
Does anyone know where I can find the torque values for 4g63's? I also need to know where to line the timing marks at. Any links would be appreciated.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Originally posted by steve
I can't imagine anyone thinking their going to rebuild an engine without service manuals but it you tell me exactly what you want the numbers for I'll look them up in my Backup Manual on CD
Steve
Cam Bearing Cap 20Nm (14 ft lbs) The order and procedure is special.Originally posted by blewbyu
I need the torque value for crank mains, rods, head and cams if you have them. Thanks
The specs are totally different between the two generations. The procedures are different. I haven't compared the tolerances but they too may be different. Save yourself some expensive grief and go to the link I provide and order the CD.Originally posted by blewbyu
[BI have online access to almost everything I need to know. i know what clearances, tollerances etc that I have to have. I have built plenty of engines over the last 15 years and its not rocket science. All I wanted was to make sure that the torque on the 4 items I mentioned was the same on a 97 as they are on a 92.[/B]
