Please Support ExtremePSI
Build finally ready.
503oneG
30
11
Sep 25, 2020
Beaverton, Oregon
So here is my setup, 6 bolt 4g63. Stock head, ARP head studs, JE 85.5mm piston. K1 racing h beams, ACL race bearings, Holset hy35, tubular manifold. Link v3 with innovative lc2. FIC 850cc, I know there is a thread for this but was hoping for a decently quick response. Say 25-28 psi ish what can I expect for power? This is an AWD manual trans. The motor is brand new built by me. Thank you, Seth
I was also curious about that. I need to start looking around for 1200 or larger. You think 850 is capable north of 400?
Depends on the fuel. I tune a hy35 car with a walbro 450 and 1250cc and at 29-30psi its around 70%IDC and logging 50-52lb/min. This is on E85 tested at 85%.
Did it make good power?
Has not been on a dyno. So all i can go off is the lb/min it logged. It should be in the high 400hp range. The car had more in it but on light wastegate spring and a manual boost controller only using lower port on gate so would not make anymore boost then that.
