Budget 2200cc injectors
cptncreme
6
Feb 10, 2017
Austin, Texas
I recently got my built talon up and running on e85, have only 1000cc injectors now so can't turn it up too much. Really want to get the fic 2150's, but damn pricey. I've found alot of the big injectors start out as a Bosch base inector. You can get these on eBay for about $50-60 a piece and get top hat to extend to proper length.. has anyone tried this yet, would be like $300 for 2200cc injectors with injectors, top hats, and plug adapters, injector resistor box delete. Here's a link to the inector
http://www.ebay.com/itm/162379160359
I understand, but I'm not looking at some Chinese knockoff injectors, these are factory legit Bosch injectors, the same way the fic's start out
Several of the vendors sell the injectors single, but state if you buy 4 or more at a time they will be a matched set
I actually bought these injectors a few years ago for my build. I saw around 40% duty cycle at 35psi with my 6262 that was flowing 63 lbs/min with a e85 mix (11.5 afr). Also, if you do buy they injectors. Make sure that you get top hats that have filters.
A decent priced brand to look at is deatchwerks, i think once you go above 800+cc any it does get abit costly anyway so expect to pay a bit or find some used,
Talon43219, that sounds like good results, how was the cruising driveability with these injectors, and do you maybe remember which size/length top hats you used?
They idle and drive just like stock injectors. I've never had them misfire or hiccup during any idle, cruise, part throttle or full throttle situations... I used the 60mm hats. But hat size all depends on the injector length you buy. I bought the short injectors.
Thanks for the info, I think I'm going to give these a go, being that it will be less than half price of the fic's or ID's
Sorry, a little confusing. It's that 60mm hat by itself or 60mm injector plus hat(total height)? I was looking at the 36mm hat for the 48mm injector, total height of 68+mm. The height of the stock injector is 71mm.
It's measured top oring to bottom oring. Should be 60mm. There are different length hats and upper oring size. Needs to be 11mm upper and 14mm lower. And get ones with filters. So I'm going to get the short injectors and the hats to make it measure 60mm oring to oring.
sounds good! I need a set for my secondary rail soon.
Contact Gamble on here. He might be able to help you out with some FID Bosch Injectors. I might go that route when I'm ready to buy mine. I want FIC 2150's but if I cant swing the cash then I will look at these FID's.
Bosch 1600s are garbage. They are what we would call "mid impedance" injectors. So yes, WOT is great but your combined FTs are gonna go haywire idle and cruise. I learned the hard way. I bought FIC 2150s and can say they are damn near as good as the little PTE 1000s i ran before.
I got a set as my secondary methanol injection. works great for this purpose. spray pattern looks good between injectors, lot of fuel at WOT. Can't tell you how they would idle or drive as primary injectors though.
There is a guy on youtube that did some testing with the cng injectors. Sloppy mechanic turbo colorado. Take it for what its worth.
im running fid 2000s on my car and they work amazing
While I’m leaning this way and most people would just buy some Id or fic injectors and call it a day. I am interested in seeing if I can cut the price of 1600+ injector in half buy doing a bosche body setup.
Hope some one have some more info.
i paid about half of what the fic 2150s are for my fids. like i said i havent had any issues with them whatsoever. idles perfect cruise is amazing with them and the car makes damn good power on them so far. we are going to really start leaning on them this year.
