1. Join the Community!
ECUflash Breaking up @ 5K +, scratching my head. Lean bandaid?
Posted by ProjectBroke, Aug 22, 2018
Please Support ExtremePSI
Please Support STM Tuned
  1. ProjectBroke
    ProjectBroke Proven Member
    60
    6
    Joined Aug 20, 2011
    Indianapolis, Indiana
    I did check this, if you look a few posts up, I had the same idea LOL. Makes sense. But voltage was fine ~13.5
    I have not. Not even sure if it’s there honestly. Your talking the little silver capacitor on the intake mani right?
    Street Build 328  1
    1998 Mitsubishi Eclipse GSX
    awd · manual · 2G DSM
    Loading...
  2. ProjectBroke
    60
    6
    Joined Aug 20, 2011
    Found multiple posts that state it is just there to filter electrical noise from the radio.
    Then I found one single post, that is having the same issue I am, due to this capacitor.
    I will check it and update.
    Street Build 328  1
    Loading...
  3. wrencher
    wrencher Proven Member
    360
    40
    Joined Nov 20, 2005
    Chicago, Illinois
    Yes....
    It dampens the primary ignition circuit from the coil firing events.
    Component "F"
  4. brian9397gsx
    brian9397gsx Proven Member
    1,560
    93
    Joined Apr 28, 2008
    sioux city, Iowa
    It filters out radio interference caused by the coils firing not interference caused by the radio.
    brian9397gsx
    3K  0
    1993 Mitsubishi Eclipse GSX
    awd · automatic · 1G DSM
    Loading...
  5. ProjectBroke
    60
    6
    Joined Aug 20, 2011
    Small update: The wire to that capacitor is frayed. Will try a new one.
    Also going to check the main ECU ground for corrosion at the pin.
    Street Build 328  1
    Loading...
  6. ProjectBroke
    60
    6
    Joined Aug 20, 2011
    Update. Redid ecu ground, replace capacitor. Added 2 more grounds.
    No change.
    Street Build 328  1
    Loading...
  7. ProjectBroke
    60
    6
    Joined Aug 20, 2011
    Update: Found wires leading to coil connector had split under the loom, someone had tied in an aftermarket tach at some point.
    Replaced wire, no change.
    Ordered new harness.
    Street Build 328  1
    Loading...
  8. ProjectBroke
    60
    6
    Joined Aug 20, 2011
    New harness installed.
    No change :(
    Street Build 328  1
    Loading...
  9. ProjectBroke
    60
    6
    Joined Aug 20, 2011
    Problem possibly solved.
    Took off the valve cover and noticed a rocker seemed out of place.
    Valve spring had broken.
    Street Build 328  1
    Loading...
    Sp1kE, dragonov_elite and Vegas smith like this.
  10. ProjectBroke
    60
    6
    Joined Aug 20, 2011
    To follow up, we had a Kiggly Street Steel spring crack and break with break in miles on the car. I have reached out to Kiggly for their opinion.
    Valve is bent, Head is unknown (haven't pulled yet, just bore-scope). Valve guide is probably cracked, piston is ok.
    Lucky it fell in the stroke where it did, it could have been way worse. Odd thing is we never heard any noise, and the valve got pushed back up into it's seat enough to pass a compression test. This had to have happened on first start or initial drive, as we always had this issue when tuning.
    So the reason going really lean helped, it was an intake valve, so basically I was flooding the cylinder since it couldn't pull in enough air (which is what I thought the problem was on a larger scale).
    Street Build 328  1
    Loading...
Share This Page
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
