- Thread starter
- #26
ProjectBroke
- 60
- 6
- Aug 20, 2011
Indianapolis,
Indiana
Annnddd no change.
Note: This feature currently requires accessing the site using the built-in Safari browser.
It really sounds like an issue with the cmp or ckp signal. Have you load tested the circuits not just ohm'd them out?
so i had an issue like that on e, cleaned my injectors and good to go, not sure how old yours are or how long since they have been cleaned but if its been more then a year i would clean them. also are you sure your gap is'nt to high? also fuel pressure set correctly? sometimes its the simple sh** you over look unfortunatly
Injectors were installed in February. Not too much run time on them since. Have thought about swapping them and checking. It’s the only thing in the fuel system we haven’t touched since then. Our fuel pressure did shoot up after the new pump/rail. But adjusted it back down. Has always been 42-43 at idle. Have gapped from .020-.024 with no change. Issue isn’t boost dependent. So gap shouldn’t be a factor.
I still think it’s weak spark. Im not sure how, but it’s what it feels like.
Next steps, swap injectors, COP?, crank sensor, then rummage through the harness and look for problems.
If you have access to another set of injectors i would throw them in real quick, couldn't hurt i tracked my issue around for so long before i cleaned them and will have them cleaned once a year from now on. especially since i dont put that many miles on my car a year so it sits alot.
id put the stock 399 maf in use a stock rom scaled for your injectors
Just sayin it'll be easier to tune... . Looked at the log the Afr is all over the place no wonder it runs like a turd. Can you not log airflow with speed density?
Swapped coils yet?
Cam sensor,
Like I asked before have you checked the signal wires from the cmp and ckp to the pcm? Actually load test them not just a continuity check? I think that's a logical place to start looking. Hell it could just be a simple pin fit issue that at those rpm the vibration is enough for it to loose some continuity that would happen so quickly not to show up on a data log but effect drivability. I see it from time to time on new cars.
