Please Support ExtremePSI
brakes
pimp4110
40
Jul 6, 2002
Buffalo_N.Y.
I just changed my rotors calipers and brakes and now when i reverse it makes a really bad squeeking noise (only in reverse though) and another thing my rear drivers side brake seems to only catch on the top 1/2 of the brake pad and the rotor below is starting to rust has anyone had this problem.
Do you hear a rattle from the car especially when going over bumps? There are clips on the calipers that hold the pad in place. I was mission a clip and it caused the pad to rattle and wear really unevenly. It also made a really bad groan when I used the brakes in reverse. Those clips on the caliper could be it. Hope this helps.
i bought the caliper loaded so i dont know for sure but ill take it apart when i get a chance. Can you buy the clips seperate. Another thing i heard something about double piston calipers from a 2g i think. does anyone know about this and where to get them cheap.
