misterskeetz
- 231
- 1
- Feb 3, 2005
San Jose,
California
Hopefully we can narrow down the possibilities here.
I noticed recently, after installing new brake lines, pads, and rotors, that when I first hit the brakes to stop my pedal goes 90% down to the floor before I feel any braking power. If I let go and press again, I get really good braking power with the pedal only pressed down 10%. As I understand it, I should be feeling the latter 100% of the time. Checked fluid level. Just as I left it after work was done so no leaks.
My thoughts on the possibilities...
1) Master cylinder has gone bad.
2) Rear calipers are going bad. (Had both fronts replaced at same time of install of other gear.
Please help!
Please help!
