Please Support Rix Racing
Boostin Performance DSM Transfer Case Upgrade
Boostin Performance
396
200
Jan 7, 2014
Hoffman Estates, Illinois
Sick of breaking your T-case? Need a reasonably priced upgrade? The Boostin Performance 300M upgraded T-case is your answer!!
https://shop.boostinperformance.com/Upgraded-Transfer-case-p/bp-dsmtcase-upgraded.htm
This upgrade starts with rebuilding your core. Seals are replaced, everything is re-shimmed for high horsepower applications, and the bearings are replaced, if needed. The foundation of the upgrade is a 300M output shaft and bored out tail shaft housing. This will mate up with your 25-spline Drive Shaft Shop driveshaft. This T-case upgrade is proven to hold 1.2 60 ft times and is built to withstand the abuse!!
Stage 1:
(*) 300M Output shaft upgrade w/ bored out tail shaft housing
(*) Seals & gaskets
(*) Shimmed for proper Bearing Preload, Gear Backlash Setup, and Proper Gear Mesh
(*) Optional: Magnus Billet Bearing Side Cover (+$225)
Stage 2:
(*) Includes Stage 1 Package
(*) BP Billet Transfer Case Mid-Housing
Stage 3:
(*) Includes Stage 2 Package
(*) Magnus Billet Front Transfer Case Housing w/ Side Cover
Stage 4:
(*) Includes Stage 3 Package
(*) Upgraded aftermarket Transfer Case Gear set. Both OEM gears are replaced with high quality aftermarket gears.
Pricing starts at $1,050, plus additional options if selected.
**Please note that the shipping rate includes packing material, shipping, and insurance via UPS. A signature is REQUIRED for delivery. Shipments will NOT be released without a signature.
