1. Join the Community!
Boostin Performance Billet Transfer Case Housing For Auto & Manuals
Posted by Boostin Performance, May 14, 2019
Please Support Southbay Fuel Injectors
Please Support STM Tuned
  1. Boostin Performance
    Boostin Performance Supporting Vendor
    258
    275
    Joined Jan 7, 2014
    Hoffman Estates, Illinois
    ** FOR MANUAL AND AUTO DSM'S!! **
    The factory t-case housing is very weak, flexes substantially, and can even break. Our Boostin Performance Billet Transfer Case Housing for your DSM, keeps both gears in proper alignment under high load situations, which keeps the tooth pattern consistent at all times. This is something that we've developed while racing the Red Demon, but is recommended for anything over 600WHP.
    Features:
    (*) Eliminates flex in the center cast Aluminum housing
    (*) Helps eliminate gear deflection
    (*) Keeps the gear tooth pattern correct even under high load situations
    (*) Made from a solid piece of 6061-T6 Billet Aluminum
    A transfer case breakage is devastating to the rest of the car, and can cause damage to the transmission, axles, driveshaft, rear end, suspension, etc. Upgrade your stock cast t-case housing to avoid experiencing a costly mistake.
    ** AVAILABLE FOR AUTO OR MANUALS! **
    Our BP Billet Transfer Case Housings are machined from a solid piece of 6061-T6 Aluminum, and is a direct replacement for your 90-99 DSM stock t-case housing. We have an option for the manual housing, as well as the auto housing, as they are different. These BP Transfer Case Housings are designed to be used in conjunction with a Magnus bearing cap, or F Fab t-case brace, and has the mounting locations needed for these options.
    Drag Race Build 4K  18  3
    1996 Eagle Talon TSi AWD
    7.04 @ 205 · 2G DSM
    Loading...
    Featured Products from our Supporting Vendors
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned VR Speed Factory White Shed Speed
