Boosted Fabrication
Supporting Vendor
- 8
- 53
- May 29, 2018
Charleroi,
Pennsylvania
We've been working hard on some new parts, There are a few new ones since we made the first post here.
Starting off the 1G rear engine mount brackets that are hard to find are finally here
793, 648, 195, and 194 are available. These brackets are also lighter than the bulky OEM brackets and designed with an easier install in mind.
Second is the 1G front and rear strut bars.
These are the only solid strut bars available for the 1G. Fully TIG welded in either Chromoly or DOM with plenty of strength in both bars.
Third is the new stainless manual shifter linkage tabs and brake line / clutch tabs.
shifter tabs will fit 1G, 2G, GVR4, CSM. Made from 304 Stainless, And wont rust.
I've also been working on a 1G front K Member for my 1G. There is a ton of time into this one so far to keep the steering rack and sway bars where they're supposed to be on the OEM K Member.There isn't much to see yet but this is something I've been wanting to build for many years.
If you want more frequent updates follow our Facebook or Instagram page
https://BoostedFabrication.com
https://www.facebook.com/boostedfab
https://www.instagram.com/boostedfab/
