awdnate
- 0
- Feb 3, 2004
martinville,
Indiana
ok, i just had my tranny rebuilt, or at least 1st and 2nd gear. and after the install, the car snapped and axle. then the t-case went dry and locked up. bad string of events. in the midst of all that after the tranny was put back in and i got it back the first time, the car wont hold boost under full throttle. it will hold under half throttle but if i go wot it drops. also before the car went in i was running 17psi, it wont boost over 10psi now. the guy that did my car (andy from indy race cores/ modern speed labs) says everything is hooked up ok except a loose line off my mbc that it pinched closed. but its been like that since i got the car so im not sure thats the problem. im pretty sure the turbo is not blown because it worked fine when i took it in. i havent had a chance to really look at it because the day after i got it back i took it back to get the speedo hooked up and thats when the t-case locked up. and tonight i didnt get it til 11pm and i just got home at 1am. any ideas on what might be causing this? thanks
nate
nate
