1. Join the Community!
boost issue
Posted by crazyquik22023, Mar 29, 2010
Please Support Rix Racing
  1. crazyquik22023
    crazyquik22023 Proven Member
    610
    5
    Joined Sep 14, 2008
    Akron, Ohio
    I had another thread on this but never resolved it. My car doesn't want to boost past 20 psi. My hallman MBC is turned all the way up and i have a tial 44mm with a 1.1 bar spring. Now if i'm not mistaken shouldn't my car be able to easily boost up to 30+ psi with this spring?? I haven't tried running the wastegate yet w/o the boost controller connected but what else could cause this problem? could it be my greddy type s bov with the stock spring?? idk let me know what u guys think. oh and also i have a pte 6262.
    850  0
    1998 Mitsubishi Eclipse GST
    12.900 @ 115.000 · 2G DSM
    Loading...
  2. kenuwine4g63
    kenuwine4g63 Proven Member
    474
    31
    Joined May 26, 2009
    Charlotte, North Carolina
    I thought 1 bar was equivalent to 17psi...
    kenuwine4g63
    441  0
    1995 Mitsubishi Eclipse GST
    000.0 whp · 000.0 lb/ft · 2G DSM
    Loading...
  3. Hitmachine101
    Hitmachine101 Proven Member
    349
    Joined Nov 16, 2009
    Rochester NY, New York
    1 bar is 14.7 psi i think and if your spring is 1.1 bar then you can double that so your correct 30psi should be able to be obtained
    do a boast leak test to see if your BOV is indeed leaking -- i wouldnt think that BOV would start to leak till at least 25psi but i may be wrong
    if your boost leak test comes back fine then id look into that wastegate
  4. crazyquik22023
    610
    5
    Joined Sep 14, 2008
    Akron, Ohio
    i did a boost leak test and it holds up to 40psi with w/o the boost controller connected and the wastegate is brand new so i doubt that is the problem... but im going to try to run the wastegate with an open side port tom. and see if that does anything b/c i think my MBC might be bad..
    850  0
    Loading...
  5. DSMDriver69
    DSMDriver69 Proven Member
    440
    Joined Oct 18, 2009
    Overland Park, Kansas
    if a blt came up neg, i would look into fule and then management.it sounds like a bov leak, which if it big enough will throw u off.
    401  0
    · 2G DSM
    Loading...
  6. Hitmachine101
    349
    Joined Nov 16, 2009
    sounds like it s pointing to your MBC -- if the wastegate is brand new then maybe its faulty but looks like a MBC
  7. crazyquik22023
    610
    5
    Joined Sep 14, 2008
    Akron, Ohio
    its not getting fuel cut or anything and its tuned pretty good, and ya it might be a bov leak
    ya im leaning towards the MBC, ill do some more test and check back
    850  0
    Loading...
  8. shinzon
    shinzon Proven Member
    276
    56
    Joined Sep 11, 2006
    St. Petersburg, Florida
    Do you have your mbc hooked up to the BOV vacuum line? This can cause your BOV to act erratically. You're better off with a pressure source near the turbo compressor outlet.
    1K  2
    1996 Eagle Talon TSi AWD
    awd · automatic · 2G DSM
    564  1
    1997 Eagle Talon TSi AWD
    Loading...
  9. crazyquik22023
    610
    5
    Joined Sep 14, 2008
    Akron, Ohio
    ugh no, i def have it hooked up to the compressor housing
    850  0
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
