Boost guage must have....but what are limits?
bosljeff
Sorry if this has been asked. I couldn't find the specific answer anywhere. Anyway, I know that one of the first things to upgrade is the boost guage especially as you modify boost levels. I know the factory guage is an "estimator". Okay, so I get the guage then modify the levels...what am I told besides what psi I'm hitting? Is it simply that I will accurately know the psi my engine melted, or is there some correlation with certain psi and certain impacts on the motor? Thanks for your help and sorry if I missed the answer somewhere else.
okay... i read that over like 30 times. So your questions are:
a) if you bump up the boost levels, what will the boost gauge read besides boost? if it reads vac then you will be told vac levels I guess
b) melted???
c) if you crank up the boost too much it's not the motor itself you will break (i am guessing you have a 14b)... the stock internals are pretty strong... you will max out your fuel system... and the turbo might get superhot and it could be damaged. also at high psi the stock IC will heatsoak in no time.
I'm sorry if those arent the questions you asked... i'm a smart guy and that's what I got from your post.
oh yeah it seems like this is not the right forum.:confused:
Thanks bro: you're right the wording of my post was similar to a schizophrenic monkey doing a math problem. Sorry. You kind of answered my questions. Forgive my "terminology" (i.e. melted), I was being sarcastic.
My question: I get a MBC and any other products that increase my boost and I am supposed to also get a boost guage. Right. So, I have all this additional psi and a new guage that now tells me accurately the amounts of boost I am getting. Very loosly speaking, is this simply for my edification, or what? I mean, I assume the knowledge of my increased psi is good to know when doing some type of diagnostic on my car (dyno, datalogging, whatever), but beyond that why is it so crucial to accurately tell how much boost you are running as you modify your car to get more boost? Can you use the guage to help you drive more efficiently (when to shift..., rate of acceleration...)? Is there some turbo troll that will simply kick my ass if I modify my boost without knowing how much boost I am actually getting?
By the way, I am getting a boost guage, but I just wanted to fully know all of its benefits. I am not trying to argue not getting one. Thanks again for your patience. Please believe me, I am beyond a newbie, but there is still some stuff (obviously) that I need help on.
Okay, done. Never again will I write anything this long.
it keeps you from hurting your motor. i'd run run 16psi max stock. the gauge is there just to tell you how high ur boost is!
Sorry to hassle, but beyond stock and the 16 psi, is there some common knowledge thing I am missing regarding what psi is okay only if certain mods have been done? Or am I just over-analyzing something simple?
Thanks
  • For sale 1g 1g rear strut brace. RRE made.
    Original RRE made rear strut brace or bar. Bolt in. Fairly lightweight also. Good for an...
  • For sale 2g 2g GSX downstream Denso 02 sensor
    2g GSX downstream Denso 02 sensor. New. OEM quality. Price is shipped in a USPS flatrate...
  • For sale 2g 2g mirror covers, etc
    2g mirror covers. Need some glue work on bottom. Difficult to find. Good condition otherwise...
  • For sale Coilover springs
    2.5" inner diameter, 7in long coilover springs. I believe the spring rate is 10kg...
  • For sale 4G63 MHI Small 16g Compressor Housing
    MHI Small 16g Compressor Housing $65 + shipping and PayPal fees* this turbo had shaft play and...
