Please Support STM Tuned
Please Support ExtremePSI
boost controller
Do you mean running the stock BCS instead of a Manual/Elec Boost controller or no boost controller at all? If you run without any kind of boost control the wastegate will open at whatever the wastegate spring is rated at. If you run with no wastegate you could severly damage your engine.
Originally posted by Defiant
You look at your aftermarket boost gauge and see how it's doing. Which was, of course, the FIRST thing you did to your car.
We can only hope so. All I see in mods is exhaust. U are fine if you are running stock routed everything. The exhaust does not require a BC of any sort.
yes very for us FWD guys. Unless you want to buy a EBC with 2 stages. It will add in traction.
