jpmxrider489
- 2,410
- 146
- Apr 4, 2010
pittsburgh,
Pennsylvania
I been trying to dial in the boost control table as I got my trans shifting better now via rpm. When I click the help icon, it says for autos, use the latest speed raw value. Am I supposed to change the gear ratio in the DA tab to match what latest speed is for the raw value? It seems like when I do the set boost tables, it wants to lower my target boost. Ill attach a log but I'm hoping someone can explain what values I need to match to what and the process to dial this in better. Log is pretty sloppy still. I'm trying to adjust this so when at the track I can just let the ecu and tcu do its thing. Also, I'm not sure how to match gear/boost when I don't think the ecu knows what gear I'm using. I'm hoping someone can guide me a little better on the correct process. In first gear, would like 17psi, 2nd gear is 23, and 3rd is all the boost.
