1SloColt
- 280
- 6
- Sep 24, 2004
port royal,
Virginia
The FP bolt on housings do flow better than 7cm^2 mitsu housings and bolt-on PTE housings. The FP housings make the scm series housing look like a schoolboy bi***, even my bullseye housing makes the scm series look bad.Slippi84 said:Where are you getting this miss information from. A 3065 is rated to 65lbs/min, I have a gt14 with the same exact chra and even a smaller exhaust wheel and both turbos are rated to 65lbs/min. Maybe a stock housing like the ones found on a 16g or so are greatly outflowed by the fp housing but not a bolt on housing found on most aftermarket turbos like the gt14 th rs65t scm61 and so on. I take you haven't run these turbos are your a n/t-T but in reality these turbos are so close in most of the power characteristics that any one of them will support 600 hp makin your points and argument void because at 600whp you got to be doing something right.
I went from a tdo5 housing 18g turbo that spooled around 3400rpm to a p-trim turbine, 65lbs/min turbo that spools at 4200rpm. The larger turbo is a much better daily driving turbo IMO.
