Please Support Rix Racing
Please Support STM Tuned
Hi everyone I thought I would do a dedicated pad selection article to cover as much of the compounds as possible rather then clog up the sale post. this should offer me more space to add them as I find them with part numbers and links if available.
While I have done my best to confirm all info is accurate please do also confirm for yourself just to make sure its correct. here is the shape you will be looking for,
FIBA MOTORSPORT caliper version
FM-PRO Billet 4 or 6 piston designed for a 17mm thick pad, can accept 16-18mm thickness.
Should you need graphs for any of these compounds to see friction and temp ratings just search the part number and compound from the manufacturer and you will find this very easily.
AP racing pad shape CP3215D50 (16-18mm thick) also can cross reference CP2279D50
EBC. part numbers, GREEN DP2002, RED DP3002C, yellow DP4002R, blue DP5002NDX, orange DP9002, RP-1 DP8002RP1, RP-X DP8002RPX,
Ferodo. pad shape FRP216, Compounds, 216H DS2500, 216C 4003, 216R DS3000, 216W DS1.11, 216Z DSuno, 216G DS3.12. This place lists it as fitting calipers CP9449 https://www.essexparts.com/search and search for FRP216
Performance friction 7767, compounds 01, 08, 11, 93
Barbaro CAC racing KD5003, C-01, C-02, C-03, C-60 C-60 is similar to the DS3000 compound. M-01 Race compound! https://www.facebook.com/profile.php?id=100063287255350
Carbon lorraine ( CL ) 5004W50T17. compounds RC5+, RC6, RC6-E, RC8, RC8-R
Brembo. B52 TBC not advised to use stock brembo road pads! To much brake fade from the road pads
PFC. 7767 TBC
Hawk. pad shape HB110.654, compounds F3000, DTC-30, DTC-60, DTC-70, HP Plus, HPS, HPS 5.0, HT 10, https://www.pegasusautoracing.com/productselection.asp?Product=HB110 also possibly https://www.brakes-shop.com/search/HB110?brake_pads_type=6338
Wilwood. 8517 TBC
Carbotech, CTCP2279, compounds AX6 to RP2, https://ctbrakes.com/product-search/
Gloc, GPCP2279 then compounds GS-1 to R18, https://www.g-locbrakes.com/products/big-brake-kits/search/?make=AP Racing
Pagid. pad shape 1361, compounds RSL 1, RSL 29. RS 14, RSH 42, RST 1 to 5. https://www.hrpworld.com/products/pagid-1361-brake-pad
Raybestos. pad shape R767, Compounds, ST31, ST41, ST42, ST43, ST44, ST45, ST47 ST57 https://www.bestbrakes.com/search/?q=R767
Project.Mu. F1076, all compounds available.
Endless. RCP015 TBC
Winmax. 814-16.5 TBC
Circo. / made by Winmax pad shape MB1648-16.5 or 17, compounds, M119, M111, M127 https://www.circobrakes.com/
Here is a company with a wide range of pad compounds and brands based under the CP3215D50 pad shape. https://www.zeckhausen.com/catalog/index.php?cPath=7398_7414
Also Summit racing is a good place to search for pads also.
I'll save everyone the time, just use Girodisc Magic Pads (I'd imagine they must be available for this page shape) for street (great stopping power, super low dust and the dust comes right off) and G-LOC pads for the track (absolutely outstanding stopping power, low dust, and again the dust actually comes off easily unlike many other track pads). For G-LOC you'll need to consult with Danny@G-LOC to confirm which compounds to use front/rear for your specific setup (I use R18 front and R10 rear).
Magic pads are not available for any AP racing caliper! they seem to just deal with oem calipers. the R10 will be good for street as i have used them before and my daily is now due to get the same R10 pads for my calipers shortly! i like how quiet they are and i get more noise sometimes for the rear 8's on the DSM.
Because its a racing pad shape for the most part there will barely be any basic compounds like an EBC black or ferodo oem type compound, the lowest compound is the EBC redstuff and the Gloc GS-1 which is like the Bobcat 1251 from carbotech. those are the only basic pads for street going i know of and wont offer any track rating at all.
G-Loc pads for my Daily cars on my 4 piston calipers. these are the R10 compounds and the same compounds i run on my Time Attack DSM also. great pads even for the streets!
