91talonontsi
- 49
- 0
- Sep 16, 2004
chester springs,
Pennsylvania
This isn't a problem with my car.. but it is a problem with my buddies car. And sence i do his work for him is turned into my problem. Anyway my friend just bought a 99 GSX with not much done to it but for a intake, BOV, and a blitz boost controller. I don't like the blitz boost controller first of all because everthing is metric. Also you can't set a real PSI to set it to.. You can only set it to a ratio. 0 is stock, and 100 is the turbo's full ratio. We set the boost controller at 70 and did a second gear pull.. and for some reason right when it reached 5,000rpm it jerks really hard (almost like a fuel cut out). It could be a fuel cut out but im not sure. But he also blew a valve cover gasket to. We tried this again and turned it down to 30. Again the same thing happen. Then I turned it to 0, that should be stock. Again the some thing happen. So then we just unpluged the boost controller completly and it finally stoped doing that.
But it kinda scares me that it was doing this. Just because i have no clue what it is. So does anyone have a clue?
