Blew a Axel seal can anyone tell me the right way to change it?
Norcalgsx707
564
Jun 28, 2012
lake county, California
Just want to know what Im going to need to change this seal do I need more seals to go along with this one, heres a pic of the leak. Also is this number the right part number?MD707184
That part is the AWD right ouput shaft seal.
As for removal: try getting a screwdriver up under the outside of the seal, then pushing part of the seal inward by hammering on the screwdriver. This pushes the seal inward, making it like a heart shape, and it will come out after enough deformation.
Or buy a seal puller.
I used a 6" crowbar I bought from homedepot. Put the 90 degree elbow in seal hole edge and gently twisted the crow foot behind seal and it popped out. Though this was on driver side and had her limited access due to the xfer case being in my way.
^^+1, its how I've always changed them
Was this a 1g ? Cause this happen to me
Do as the others have suggested to remove the old seal. To install the new one, if you have a socket close in diameter to the seal, tap the socket with a hammer lightly to drive the seal in place evenly until it seats.
Thank u very much , and all ur advice ,,, I am buying part number MD741818 oem. As we speak ,,, ,,, this will cause me two leak tranny fluid right , ????? And not shift ,
