Big, or small problem?...
TsiTalon90
159
Dec 23, 2002
Granby, Massachusetts
Ok when i bought my car the guy put in a new clutch , pressure plate etc. Recently i've benn noticing it loosing master cylinder fluid very slowly. Anyway its been a few mounths and my clutch is ingaging,dissangaging near the floor and sometimes it sticks there. So i decide to re-bleed it. Dosnt fix it. I bring it to a mechanic down the street and he says its an internal problem. It woont hurt it driving around like this but when you in N and you push the clutch in and it dosnt ingage you get this embarassing grind.
What am i looking at here?
thanks:confused:
your master cylinder or slave cylinder are bad. Slide the boot back on the slave and if fluid comes out then its bad. Look behind the gas pedal on the firewall ( inside the car) and see if theirs fluid leaking down from the rod sticking through the wall if there is then the master is bad.........
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
  • For sale 2g 2GA Eclipse Fog Lights & Brackets
    2GA Eclipse Fog Lights & Brackets $70 + shipping and PayPal feesYou must be registered to see...
