volkri25
- 61
- 0
- Nov 4, 2008
Tempe,
Arizona
Had my car tuned today. Runs great minus 1 thing. Im building to much boost to fast with my car causing a pretty severe compressor surge at a low rpm range.
Im getting 30psi by 4k rpm with my H1C and it seems my car cant flow enough at 4k for it. Its really bad in 3-5 gear, and is obviously unoticable and short lived in 1st and 2nd. Now If I do pulls through the gears, and shift into the next gear while boosting around 5k rpm the surge doesnt hit. Its only from 3.5k to 5k and at around 7psi to 15psi. Never surges after im past 15psi. I know this isnt as bad as having a stuck wastegate with a full load of boost but the car performs slow in a cruising state of driving.
Mod list:
9.0:1 wiseco pistons
eagle h-beam rods
6 bolt block
bc 272 cams
bc retainers and valvers
fidanza adjustables
7 bolt head
evoIII intake manifold
1g 60mm throttle body
vrsf intercooler
fp exhaust manifold
H1C on a .55ar bep housing
punishment racing 2.5" o2 housing
tial 38mm external wastegate w/ 17psi springs
tial 50mm q bov
megan racing dp
tsudo n1 exhaust
Basically I am looking for the most reliable solution. Got the car tuned today, however cams where not adjusted, not sure if this would alleviate the surge. I have a 10psi spring in my q which is 2 psi too strong for my vaccuum level, however the surge happens in boost, which means BOV couldnt be the culprit.
I feel helpless on what to do. The 9.0:1 pistons are helping it spool just way to fast, same with the evo3 intake. I feel like switching to a t3 .70 ar system would lesson the backpressure enough.
Opinions and help would be GREATLY appreciated!
-Kyle
Mod list:
eagle h-beam rods
6 bolt block
bc 272 cams
fidanza adjustables
7 bolt head
vrsf intercooler
fp exhaust manifold
tial 50mm q bov
megan racing dp
tsudo n1 exhaust
-Kyle
