Between the turbo & manifold?
white 90 gsx
216
Sep 4, 2002
ft lauderdale, Florida
I have a simple question when installing the new turbo my mechanic just put the aftermarket metal gasket between the manifold and the turbo by just putting the metal gasket on. The question is should you put anything on the gasket or something to help make a proper seal? Because it seems as if the metal gasket will not seal it properly because the fact that its hard steel. Or can you just put it on without adding any type of gasket maker to it?
Yah the metal gasket is just thick enough and not to dense that when you tighten the bolts to spec it actually crushes the gasket slightly leaving it imprinted in the gasket making a nice tight squeeze.
  • For sale 1g 1991eclipse gsx 5speed AWD Turbo
    1991 eclipse gsx 5-speed AWD Turbo
    • silveriadominic
    • silveriadominic
  • For sale 1991eclipse gsx 5speed AWD Turbo
    • silveriadominic
  • Wanted 2ga eclipse/talon side skirts
    I am in need of a set of either 2ga eclipse/talon side skirts. I’d prefer black but I’ll take...
    • CertifiedBot
    • CertifiedBot
