Best cams for my nt???
TKI
40
Oct 10, 2002
I was thinking about ordering me some cams for my car, but before I did, what does everyone else use?
What stage would be the best to use? I would like pretty good idle with good gas milage. I had looked at the crower stage 2's, but are they good cams?
Also, right now I have a CAI and HKS dragger style muffler, but I do plan on modding more.
Any suggestions are welcome! TIA!
might help if you listed the type of car you have...I'm assuming a second gen.....there seems to be quite a few cams out there to choose from for you ....DOHC neon cams might fit too...pretty sure they would, but you'd have to look into it...I think crower has a description of what you can expect from each of their cams
I think if i were you i'd wait to get cams. I love cams and think they are an under-used and underappreciated mod in a lot of imports especially dsms. With you current mods you would be better off getting a full exhaust including header and maybe some more on the intake side too such as a larger throttle body and such. To really see the full effect of new cams you have to open everything up because your engine will be taking in and letting out a lot more. No matter what cams you get your idle will be different, it will be even lumpier than it already is, and gas mileage will go down, that's also inevitable. Also if you have to pass emissions you won't.
i have crower stage 3 cams and cam gears. and it weird because the cams are not stage 3 specs. their custom specs 258\258 duration and 446 lift stage 3 specsare .258\.258 duration and.374\.374 lift.
  • For sale 4G63 Parts
    Transmission starter plate fits 2G DSM 7bolt engine for Auto AWD or FWD and FWD Manual...
    • Dsm_canadian_mike
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
