2G Bee R rev limiter install?
2g spyder eclipse
391
Apr 30, 2013
Milwaukee, Wisconsin
Ok, so I bought a bee r rev limiter. I don't see any write ups on how to install it for a 2g eclipse. Anyone have one installed? I know there are a few wires. Ground, Power, RPM signal, IGN signal, and clutch switch. I am guessing I can hook the ground and power up to anything that powers with the accessories like the cigarette lighter. But where do I tap for the IGN and RPM signals?
http://www.dsmlink.com/images/forums/2GECUPinout.pdf
http://www.dsmlink.com/images/forums/2GECUMFI.pdf
These should help. I have no idea what the "Bee Buzz revver" wants to see but these are all the wires in your car. Of course nobody on here has that thing installed, we run ECMlink or use our feet for launch control. I would sell it and put that money in the "get ECMlink or equivalent" savings account.
YUP:
http://www.driftworks.com/forum/technical/45065-those-interested-bee-r-limiter.html
SELL IT.
Where do I hook the wire up for the "ignition signal". I'd assume that's what cuts the ignition? So what would I have to tap into for that? I am gonna hook the RPM signal to either pin 58 or 89.
Ignition signal? As in a signal that the ignition is engaged? As in the key is in the "igtion-on" position? That can be found in the ignition harness near the key hole under the steering column.
I'd assume it means like actual spark possibly? Because it's an ignition cut rev limiter. So it has to interrupt the signal I believe.
Damm that thing is old school it was the cool thing to do in the early 00's .. Dont know why you would need it now it's not a 2step is just a limiter that cuts spark and shoots a lil fireball sometimes..
Ok, I have the RPM wire right. It flashes when it reaches the set rpm. But the car is not cutting ignition. I wired the green wire to the Crank sensor and I guess that doesn't cut ignition.. What will!?
Probably because no one on here has ever installed one of these crap devices. You could just use google and easily find what you need instead of getting angry with members on here.
I am asking here because these devices are made for nissans and such. I just wanted to know if anyone had installed, or knew what would kill the ignition. And I am sorry, but it's quite annoying when someone always just post "what is this for" or "why are you installing this". It's obviously a rev limiter. That'd be why I am installing it. It's pretty self explanatory...
But it's isn't really a rev limiter. It's a gimmick that cuts spark up top so you dump fuel into the exhaust for the "super cool flame." Frankly, we're all just trying to save you from wrecking your wire harness on a little toy for that JDM scene yo.
