Beater Help! Auto Tranny guru's
Wheels-a-turnin
225
Apr 1, 2003
troy, Michigan
Ok here are the symptoms, when i first start the car its fine and drives normal untill say a mile into my trip when i accelerate it has trouble shifting into gear, and then soon after that its like its in nuetral when i have it in drive. Then i turn the car off and back on and the process starts over again. any help would be awesome.
Start with changing the tranny filter and the fluid. Sounds like the same problems I was having with the shifting from 1-2 and 2-3. If your problem is OverDrive then it maybe your End Clutches. My problem was first slipping while in OverDrive and then eventually the slipping from 1-2 and 2-3. The cause was the End Clutches were worn and the shavings from the End Clutches were clogging the Tranny Filter.
fwm
Your filter is clogging up with debris. If you change it you may get a few more weeks out of it.
-John
Owner, import performance trans
