joOse
- 59
- 16
- Mar 21, 2011
Hopewell,
Virginia
I just got done installing moog ball joints on my lower front control arms. After I pressed the ball joint into place and installed the snap ring I noticed there is bout a 3 mm gap in between the bottom of the snap ring and the top of the control arm mating surface. The balljoint is tight and properly pressed but I'm worried that it might come loose since the snap ring really isn't appying any pressure? Is this common with after market ball joints? Will it be ok?
