balance shaft alignment hole on back of block
nicklesmack
71
Oct 16, 2009
phoenix, Arizona
Does anyone have an extra block layin around that can spare this bolt i have a massive oil leak i called mitsu the can get it for 5 bucks but wont have it till tue can anyone help
I
I dont know the thread of the bolt if anyone has an extra one i will replace it with the one i order from mitsu i just dont wanna wait till tue
I Didn't remove it i just got it. i knew it was leaking oil but couldnt find it i googled common oil leaks in that location that came up so i checked but anyway my motor still has the balance shaft belt it's just a way to make sure it's aligned you stick a screwdriver in if it goes in it's aligned if not you have to reset the oil pump sprocket
