4Motion4g63
- 257
- 0
- Feb 27, 2005
Lawton,
Oklahoma
I just finished Installing a Set of Baer Brakes on my 91 AWD, and Backing out of the driveway for the first run, I Got 3/4 Of the way out and pulled back into the garage..
There Is a Terrible Grinding From the Rotor Dragging on the Lower control arm, at the edge where the ball joint mounts! Another problem is the rotor fits with allot of play around the hub? These brakes came off a 91 AWD used, Am I missing some shims? Do I just clearance the control arm enough to clear the rotor? How Do you center the rotor on the hub?
There Is ALMOST a 1/4 inch gap between the center hub and the inner edge of the rotor.
Sucks man i wanted to do Stoppies this weekend....
I guess the brakes already shaved some metal for me....
Sounds like some negative feedback is in order. The seller sold it as a 1g kit and it's really a 2g kit, that's definitely not cool.
I can also find cheap ebay slotted drilled rotors for the mustangs for about $180 a pair...
Yea the 2g kit was a 12' rotor and the cobra 1g rotor is 13' rotors would not work, so washers and wheel spacer will make it fit for 1g using a 2g bear brake kit...
