BAD Stutter/sputter Problem from 4k-6k
pickens
544
5
Jan 17, 2003
Southern California, California
Hello all, this is my first problem/question to the board. I recently picked up a 97 gst and the car was running fine. I put a KN filter on, and now the car pulls good up to around 4k rpm and then stutters(loses almost all power) until I get to 6k rpm and then it takes off like a bat out of hell again. I replaced the stock airbox and filter to see if i could get it back to normal, but it still did the same thing. So I then put the KN back on, changed the plugs, and it got a litttllllle better. I made sure every intake hose was super tight, I checked all the vacumm lines I could see. Oh, and if I try to make it keep revving when it stutters in the mid range, the CEL will come on after a few times, but it doesnt come on if I just cruise around all day, only when I push the motor to do something other than cruise.
My guess is possibly a bad fuel regulator, or pump, and maybe spark plug wires. But those are just guesses in the dark. Maybe I messed up the maf or something weird when I put on the KN.
I need help bad because this is really frustrating me, so if you have any advice whatsoever, I'll take it!:thumb:
usually when the car hesitates it is an ignition problem check your plug gaps? .28 is what you want change the wires and what plugsh are you using?
