YERFDOG
- 89
- 37
- Feb 10, 2013
Bay Area,
California
Hey everyone,
I have had this issue since I bought my 2G GSX back in December. The car pulls to the left at pretty much all speeds. On the highway if I let the wheel go, it'll crossover lanes pretty quickly. The car had stock GSX wheels on it with pretty bald tires on the inside edges (front). I got a set of EVO 9 Enkeis with tires that have pretty good meat /normal wear on them, but they are from 2008. I have had it aligned TWICE (2 different shops, couple months apart). Both days all TOE adjustments were out and corrected (see below for most recent). The front right CAMBER is off pretty good and the shop said this can be causing the pull. The cars struts look to have been replaced with an OEM replacement at stock height and controls arms, ect..all look okay. Nothing abnormal or bent as far as I can see. Car has NOT been in an accident either and is straight. Tires pressures are all even at 32.
I have yet to try and rotate the tires to see if it changes direction or gets any better or worse. The odds of 2 sets of bad tires is not good but you never know...
My question is what would be throwing my front right camber out of wack? Also the front left caster is funky...
Thanks!
Thanks!
