1fastlaser
- 965
- 0
- Jan 25, 2003
glendora,
New_Jersey
Setup
to4e 57, pte 680s,custom fuel rail,paxton rising rate set at 43psi vacuum off,walbro 255 rewired,-4 lines to and from the fuel rail,vpc 550 chip,afr,eprom stock chip for now,2g pistons with 190 or alittle higher across the board.
on the logger full throttle 3rd and 4th pulls,i get .35 highest on my o2 voltage,which i know not to tune off of,and my egts which arnt something you are supose to tune off of eather dont go passed 1100 in a 3rd and 4th gear pull.Egt might i say is in the downpipe.
all my afr settings are 3500 -19 4000 -19 4500 -25 5000-25 all till 6500 and 7000 were im -23
i tryed riching it up to -15 -10 but the car feels slugish and dosing go,knock is gone but car is slow.Base timing right now is 5btdc.
what to do? Bad o2 sensor giving bad readings so it thinks its lean.2 bad knock sensor or not torqued to block right.I was gonna pull some timing and try it,then add some timing with the extra fuel and try it.If theres anything else i need to add or answer so i can have some insite please post
