1. Join the Community!
1G Bad idle after I put throttle body gaskets on wrong
Posted by mitsuowner1991, Oct 12, 2019
Please Support STM Tuned
Please Support Rix Racing
  1. mitsuowner1991
    mitsuowner1991 Proven Member
    224
    4
    Joined Sep 29, 2009
    West Keansburg, New Jersey
    Car was running ok.. went and changed the thottle bodie gaskets and by accident i put the one on the wrong way and i started the car the idle srarted surging. So i looked under hood heard the hissing from the TB gasket i put on wrong.. so i corrected the gasket and no more leak but i still have the surging idle.. Can you mess anything else up if to much air gets in there? Im starting to think it somehow messed the TPS up.
    133  1
    2005/HONDA/CBR600RR
    rwd · manual · Misc Vehicles
    84  1
    03 Volkswagen Jetta 1.8t
    fwd · manual · Misc Vehicles
    Street Build 384  5
    1991 Mitsubishi Eclipse GSX
    16.396 @ 83.38 · 1G DSM
    256  0
    · 1G DSM
    Loading...
  2. pauleyman
    pauleyman DSM Wiseman
    5,434
    1,227
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    No. But you probably inadvertently fixed a leak and now your idle needs readjustment. So do that.
    Street Build 3K  1
    1997 Eagle Talon TSi AWD
    awd · manual · 2G DSM
    Loading...
  3. Lucky13
    Lucky13 Supporting Member
    116
    35
    Joined Nov 20, 2002
    Palm Beach Gard, Florida
    Do you have DSMLink or similar to check the TPS voltage at idle?
  4. mitsuowner1991
    224
    4
    Joined Sep 29, 2009
    My super afc does. And i made a little setup to check it i have the tps to .49 at idle
    133  1
    2005/HONDA/CBR600RR
    84  1
    Street Build 384  5
    256  0
    · 1G DSM
    Loading...
  5. Lucky13
    116
    35
    Joined Nov 20, 2002
    The car wants to see .63 at idle so I'd start there. Fixing the seals is also probably going to affect your BISS screw adjustment.
  6. Cherry
    Cherry Proven Member
    198
    52
    Joined Jun 16, 2019
    Hull, Georgia
    The factory manual says .48-.52v. ECMlink wants it at .63v.
    There are many places air could be leaking though I would at least try to adjust the BISS first. With how old these cars are seals start to get hard and could start to leak. Injector insulators, BISS o-ring, vacuum lines, gaskets, shaft seals, ISC o-ring, FIAV housing o-ring. If adjusting the BISS doesnt work start checking for cracks or hard seals.
    Street Build 352  3
    1991 Mitsubishi Eclipse N/T
    fwd · manual · 1G DSM
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
