bad exhaust valves?????????????
bretthejet26
158
Aug 24, 2002
burlington, Massachusetts
hi, i usually think the worst when it comes to poor performance, so im gonna throw this one out.... well i replaced the head of my 1g about 6 months ago (timing belt incident).... since then i've added a 2.5 downpipe and 4'' exhaust from buschur... and also a hallman mbc. now, im kindof worried because i think i've been detonationg BAD.. but its weird because boost has not been over 14psi (1 bar).. the most boost i've been running at any given time would probably be 12psi. i still have the stock fuel filter in there, and i dont have a thermostat in the car (im dumb i know).. but anyways my problem is similar to the bogging problem everyone has... but the wierd thing is that my vacuum on the boost gauge (blitz) reads -9psi at idle.... which is bad considering a month ago it was around -12_-14psi.. so im worried that there is something major wrong... or it could be just a vacuum leak... but if anyone has any symptoms of bad exhaust valves let me know? thanks
do a compression test. I've seen similar symptoms indicative of: bent valves, dead piston rings, or even a blown head gasket
  • For sale 2g 2g cylinder head
    2g cylinder head. Overall good condition. Ran it in the ultrasonic tank. Came out pretty...
  • Wanted 2g 2G 3rd Brake Light For High Rise Spoiler
    I melted a hole into my brake light's red shield, so I need the red part or the whole light...
    • dsmnagi
  • Wanted Wanted TCM
    Wanted TCM FOR MY 1991 eagle talon, awd tsi, automatic
    • ArthurCharland
  • For sale 1g 90 Oil Filter Housing and Oil Cooler
    90 air cooled oil filter housing. 90 OEM oil cooler with custom lines. Takes 18x1.50 mm...
  • For sale 2g 2G AC Tensioner Bracket
    2G AC Tensioner Bracket $45 + shipping and PayPal feesYou must be registered to see...
