rossb
- 375
- 1
- Oct 9, 2007
Wilmington,
North_Carolina
First off since I haven't edited my profile my talon has a Walbro 255(or at least the previous seller said it was there), and an evo III 16g(running stock PSI, 14b blew up)
O.K. heres the story, fired up my talon let it warm up,was cruising at about 55 then I felt the power give out I could rev it but, the tach. would not move above 1.5k, and the check engine light came on. After a few seconds, it would jump aback up to normal RPMs and accel. fine(no jerking or anything), but then it would drop again and repeat the process. I pulled on too an off ramp and it cut off on me(scariest moment ever going ~50 on a ~35 off-ramp with no power steering, so I hit my breaks and they locked up too). But after it sat for a few it started up perfectly and started driving fine. Then a few minutes later it lost power thing again but went right back to normal. I know you all are thinking "fuel cut", but when I come to a complete stop and try to get it to go in first it wont, the ONLY way to get it to go, is to rev it above 3k and dump the clutch. There was also shifter vibration and a scraping noise when slowing down with the clutch in, and all other gears seem fine shifting wise..Any ideas?
p.s. Sorry for the long post, i figure the more details the better.
