architechnik
- 690
- 10
- Jun 21, 2007
Glad,
Oregon
How do you get the B-column cover off of a '94 Mitsu?!?!
I recently ripped out my headliner to replace that usual dull brownish-gray material that sags down makes me want to gag each time I notice it.
I pulled the A frame covers off real easy, took off the all the little plugs and visors, lights, etc...
Then I removed the one screw and tried to pull the covers off the frame just behind the driver's side. *SNAP*
"Ok, I'll just glue that part back on when before I repaint it black."
Checked for any other screws/points where it could be attached still. Pull. *CRACK*
"Ok, well. I can get the headliner out on this side now, but the cover's still attached. I'll check the other side."
*SNAP* "SON OF A MOTHERLESS GOAT!" That was the point where i nearly lost it.
I've got the headliner out and prep-ed with material, soon to be glued, but I've got to get those side pieces out to get the headliner back in. Is there some magic button that releases these covers that seem to be attached in the center?
If no one responds soon, I'm busting out the crowbar. I'll build pieces out of Play-doh to replace it if I have to.
