rhodes2010
- 118
- 5
- Apr 17, 2010
Palmdale,
California
I searched this, some part numbers came up. Websites like Mitsubishiparts.com were not as helpful as I had hoped.
AND - going to local auto parts stores: NAPA, Autozone, Oreilleys all were a fail for me on something that should be EASY. I wanted to purchase Axle seals for the front CV axles on a manual transmission 1996 GSX AWD.
Found a hundred thread/posts about people replacing axle seals. Also learned that maybe the words axle
seals are not the correct words. Maybe they are called something else and not axle seals.
For some reason the local autozone/napa/oreilly all had the seals for the REAR, which I found odd as that is
less common, And these seals must be the same for a GST and GSX, just my guess.
I fouund references to Output shaft seals:
MD719710 Left Side for $10.
MD707184 which said right-side and also Rear. so not sure.
MD710317 as an extension housing seal (transfer case seal ??)
MD710259 Left output shaft $16
MD712007 input shaft at $5
Trans is a W5M33-2
This should not be so difficult. Anyone done these and have some guidance on what they are called and where to get them ?
Maybe some part numbers from your packages. Sorry for the dumb question, or if this has been covered.
Thanks
Trans is a W5M33-2
Thanks
