Awdmonster drag car
Last weekend I got the opportunity to finish the paint job lots of work but finally got it done
The next order of business is getting the motor back from the machine shop
Update: since the engine was out decided to remplace all the old bushings and tie rods and give the subframe a deep cleaning
The hardness is pretty much done still need to test it
Next in line is getting my flywheel resurfaced install a 12 tooth kiggly trigger plate setup put the motor and Trans in the car ...
Almost there ...
I maneged to get some help from my friends after a few things I needed to install got the kiggly 12 tooth in
Oem timing belt new COP
And dropped the engine in to the car
Found out I need to get a sub hardness for my fail safes for infinity getting pretty close to a runing car
update: I removed the dash but I can't make up my mind if I should keep the dash or remove it. I would like to see more 1g race car ideas if anyone has any they will be apressiated.
Also got me a 2g speed sencor forgot to work for aem. Fixed my radiator brakets
Made a dandy mount for the aem
its been a while since ive posted I finally got a 10 pt cage on the car working on getting it certified by the nhra.
i will post pictures very soon tomorrow ill be working on the car posting more updates
Finally got the wiring harness for the infinity 508 took me long enough since we had to make changes and attention to detail is a must. I have a friend helping me he though this since my wiring skill are not all the way there. We are also making a aluminum dash
Soon I’ll post more pictures
