1. Join the Community!
Awd vs fwd flywheel
Posted by Mizzat508, Jul 5, 2010
Please Support ExtremePSI
Please Support STM Tuned
  1. Mizzat508
    Mizzat508 Proven Member
    35
    Joined Apr 2, 2009
    Londonderry, New Hampshire
    So I did a clutch, act flywheel, and 14b on my eclipse this weekend. I went to start it and the starter just spun. The flywheel is for a 2g awd eclipse, and fit fine with my clutch. It seems like the starter isn't making contact with the flywheel teeth. Did I install the starter wrong? Or is an awd starter different from the fwd? If so, will an awd starter solve my problem or will I need a new flywheel? I need answers asap, so I can give my friend his spare car back.
    If it helps I've got a 2ga eclipse gst, I put an xtd stage 4 clutch 2300lb pp, and the act xact 11.9lb flywheel.
    Sent from my Droid using Tapatalk
    273  0
    1995 Mitsubishi Eclipse GST
    15.871 @ 93.120 · 2G DSM
    Loading...
  2. LTUDSM
    LTUDSM Proven Member
    1,323
    4
    Joined Jun 27, 2005
    Morrisville, Pennsylvania
    the awd flywheel wont work on a fwd dsm. Get the fwd flywheel and you will be good to go...... and fwd flywheel wont even in the awd tranny,because the tranny housings are different.awd has a bit smaller tranny housing.....
    485  0
    1995 Mitsubishi Eclipse GSX
    · 2G DSM
    Loading...
  3. -TunedDSM-
    -TunedDSM- Proven Member
    527
    4
    Joined Feb 12, 2006
    Traverse City, Michigan
    Yup, the AWD flywheel is smaller than a FWD flywheel. You'll need to pull the trans and replace the flywheel :(
    446  0
    1990 Eagle Talon TSi AWD
    manual · 1G DSM
    Loading...
  4. Mizzat508
    35
    Joined Apr 2, 2009
    Aaarrrrggggg. Alright. Guess that's what I get for buying the awd flywheel without checking first.
    273  0
    Loading...
  5. spydergotboost
    spydergotboost Proven Member
    55
    Joined Dec 14, 2003
    feeding hills, Massachusetts
    i got a used fidanza FWD fly wheel we can work something out for if your interested. and im only in MA PM me if interested
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
