AWD 1g Back from the dead
Picked up some evo 8 rims
Ditching the bumper exit, its way to lound cant even drive the car without glareing looks and worry of getting pulled over every second. Managed to snap a bolt off in my tial too.
My buddy bought a hx setup off the classifieds came with a v band exhaust setup. He changed his mind and is now going bep so i bought the stainless v band sections off of him. Started to chop it up to make it work. Feel a lot better with an actual v band vs the steel welded to cast like i had.
Swapped out my rear control arms for afco tubular, and rear shocks with kyb and tien springs.
Well my tank started leaking so picked up a fuel cell, two inline e85 filter 100 micron and 9, an line+ fittings,
bosh 004 inline pump
Also some FIC 2150cc high z's
My car is still undriveable from the clutch issue going to be replaceing it the coming weeks just trying to get the fuel system buttoned up.
So my clutch disk, tob, and trans sleeve "2g" got destroyed
Swapped out the nylon -10an in the bay for ss
Some pics of the new clutch setup. Couldn't find a tob sleeve had a machine shop make one up for me.
Definitely a cool little build. Looks like you're having o2 sensor issues?
assuming you saw my post on facebook. My last sensor broke it lasted about 5 months throws a 04 code. replaced it two weeks ago with a new one just got the 08 code on Saturday. I'm really hoping pepboys will replace it these $55 sensors add up
well i made it to the shootout 2018 ran a 11.46 @125
added a 02 spacer a month back seemed to have fixed my or overheating.
also did the tail shaft recall kit. My transfer case leak is finally fixed. Scored a sweet deal on a smim manifold at the shootout hoping to brake into the 10's
