Auto Tranny Book
BlackRaptor
203
Apr 18, 2005
Owatonna, Minnesota
Anyone know where i can get a book with a complete break down of my auto tranny?
I went to my local trans shop and ordered a ATSG book for about $15
Has a good breakdown and assembly .A must have for auto's
Haven went here but this is there link www.atsgmiami.com
Thanks guys
I was looking and it's 125 bucks for a rebuild kit for our trans.
used or rebuilt is 1500+
How hard are they to rebuild if your careful and take it step by step?
Funny thing is my tranny works awesome. i think the valves aren't sealing because it won't fill the TC. but if i shoot air down the tranny fill line like 25-40 psi it jumps into gear and is good to go. and i can go into park R N D 2 L no problem.
just nees a shot of air so i think the valves aren't sealing.
someone was saying the valves in under a plate inside the tranny fluid plan. is this true?
Also thanks for the link i'll be ording up a tranny book asap.
I got the kit from Ipt and there was ALOT of pieces in that kit so I was a little nervous about taking my tranny apart but I got it. The kit had pieces for other styles of DSM trans so there was extra stuff when i was finished. If you can follow instructions and be patient i'd say you should be ok. Get the book and look it over first to get an idea of what is involved.
As for the valves/solonoids they are on the other side of the valvebody. Pull the pan then the valvebody solonoids are right there. The solonoids have o rings on them try replacing those first. It's easy but the book helps alot.
