greanbeans
- 461
- 0
- Nov 17, 2011
jacksonville,
Arkansas
Hey Will see tomorrow... if not i have to rid of it i cant afford to keep putting money in it.
How much if it comes down to it
Thats is nice bro. what's the next step? How is your leg/knee?
Ugh. x.x Give me a burger and fuel and I'll come Diagnose and fix what's fixable Saturday afternoon.
Thanks AL... my knee is getting better I think. I got a doctors appointment today at 2:45 with orthopedic Arkansas.Going to find out if their going to have to cut it off (j/k). I don't know what my next step is. James is really wanting me to buy his car and he found me a good deal on an awd trans and transfer case but then I'll still need the rear diff and a new exhaust setup before I would be able to use it. Well actually all I'll need is a down pipe but that's getting real close to my 2k budget. Just for his shell, the awd trans, and transfer case that puts me at 1300. Then maybe an extra 300 for a rear diff 1600. If i do the auto to manual swap the only parts I'll need is the braided clutch line, whatever mounts I'll need for the trans, a new clutch,down pipe, and I would like to get another flywheel like I had. That puts me well over the 2k mark..... Idk what I'm going to do. I did almost have the guy here in searcy talked into selling me his awd talon and it comes complete with an engine and trans for 1000 but he is tore between selling and keeping. One minute I'll have him agreeing to sell and the next he wants to keep it.............
No the car running fine...what I'm not getting that the rods aren't bent and the crank not egg shape, why the bleep it keeps spinning bearing on the same cylinder?
Don't give up just yet. Ask it on the open forums. Maybe get a second opinion. (Alex why are you not a wiseman yet?)
I have a lot to learn. I know a lot about a little. To be considered a Wiseman, you have to know a lot about a lot - and there's a lot that I still haven't put my hands on.Is your oil port clogged, not allowing adequate oil pressure to the bearing. Have you mic'd that journal to make sure it's in spec for the bearing that's being used?
^ Aye. I'm willing to bet on an oiling issue or a groove in the journal from the first spun bearing. If it's a small groove that's not too bad, you can use a leather boot lace, emery paper, or high grit sandpaper (2000ish) coated in oil and go around the journal lightly. If there is a mild to bad groove/notch/scar then the crank will need to be removed and taken to a machine shop.
Could also be installing the bearings wrong by mistake.
what about not torquing the caps down tight enough?
Loose caps could do it too. What kind of torque wrench you using to torque them with
well i have been tryna to find that out the book say 18ft lbs but colby and a few other people told me 38 ftlbs
Don't forget to check for scaring on the crank journal.
.Well let me know if someone has a valve cover!
Come down Saturday afternoon and help us tune if you want. I can swing the food for sure.
no but for real, y'all should go also.Take it to the trackno but for real, y'all should go also.
Will have to see what we have going on. What time does it go on.
By the way, for us fwd guys, Jacksonville high school has a dyno. Haven't got a price for it yet but glad I have a dyno less than 5 miles from the house.
