Canadian_CD9A
Supporting Member
- 1,086
- 861
- Feb 10, 2012
Winnipeg,
MB_Canada
The JUN 272 used to be the hottest cam over 10 years ago, but times have obviously changed. I'm asking to see if Jun's cams are still relevant in the 4G63 world. There are publications out there showing that they are machined to impeccable tolerances, but according to the DSPORT cam test, the JUN 272s give up spool compared to cams that make similar power (GSC S2, Kelford 272). The JUN 272 had similar spool-up characteristics compared to the GSC S3, but with lower peak numbers. Keep in mind, that was an Evo test, so I don't know how well this applies to DSMs/Evo123s. At the moment, I can buy a set of new JUN cams cheaper than a set of GSCs, which has historically been the main issue that made people buy elsewhere. Are the JUN 264 or 272 still a good choice for camshafts these days?
And also, can someone finally produce accurate duration numbers for the JUN 264? Strangely, this has never been shared online.
