1. Join the Community!
Any good DSM mechanics still turning the wrench in SD?
Posted by Raptor1, Aug 15, 2020
Please Support VR Speed Factory
  1. Raptor1
    Raptor1 Probationary Member
    4
    Joined Jul 29, 2013
    SAN DIEGO, California
    I've got a '90 Talon TSi and '90 Eclipse GST I'd like to get started. All parts complete...need a good mechanic... won't start and it's not the battery.
  2. Big Mo
    Big Mo Probationary Member
    8
    Joined Aug 15, 2020
    carson, California
    Theres a shop in santa fe springs.. there good peoples. i know there a distance away but im sure if u call em they can help ya or send ya in the direction to one in sd maybe. Not 100% sure though. http://roadraceengineering.com/blog/
    Street Build 149  1
    1995 Mitsubishi Eclipse GST
    fwd · manual · 2G DSM
    Loading...
  3. Raptor1
    4
    Joined Jul 29, 2013
    Thanks for the reply. That's a bit of a drive. I'll give them a call to see if they can recommend someone in SD.
  4. Sniffbooger
    Sniffbooger Proven Member
    215
    72
    Joined Apr 12, 2020
    Torrance, California
    I am nearby in LA...used to live in SD for 25yrs...still have friends there and come down to visit...what exactly needs done with the cars? Are they in pieces, all torn apart? Or just been sitting around and need to get them running?
    Street Build 334  8
    1998 Mitsubishi Eclipse GST
    Loading...
    Raptor1 likes this.
  5. JediMindBlazZin
    JediMindBlazZin Proven Member
    87
    42
    Joined Nov 25, 2011
    Palmdale, California
    Mikey is well known in SD. Here's his IG mikey_spec
    1K  7
    1990 Mitsubishi Eclipse GSX
    488 whp · 389 lb/ft · 1G DSM
    29  2
    1998 Mitsubishi Montero (Winter Package)
    awd · automatic · Misc Vehicles
    Loading...
  6. Raptor1
    4
    Joined Jul 29, 2013
    Both are complete and not in pieces...just need to get them started and running again...could be starter relay, fuse, or starter.
  7. Sniffbooger
    215
    72
    Joined Apr 12, 2020
    How long have they been sitting? I'm sure we could figure out a game plan.....what area of SD?
    Maybe we could make an appt and I'll come take a look... It's always basic things first...all cars need fuel, spark, compression and timing to run...if the starter isn't turning over the engine, it could be a battery, a relay, a fuse, a cut or broken wire, a bad ground, a malfunctioning alarm or kill switch, etc...there are def some things we could check out.. the weather is gonna be hot this week...maybe an evening would be good? Message me for contact info..
    Street Build 334  8
    Loading...
    Raptor1 likes this.
  8. Fireraven
    Fireraven Probationary Member
    25
    12
    Joined Aug 13, 2020
    Iowa Park, Texas
    Better check the clutch safety switch.
    Showcar Build 349  2
    1990 Eagle Talon TSi AWD
    awd · manual · 1G DSM
    Loading...
  9. Raptor1
    4
    Joined Jul 29, 2013
    It's been a year or two in the garage (both of them) and I tried a new battery. Could be any of the things you mentioned above: fuse, relay, or starter. If it's okay, I'll PM you. Thanks.
Share This Page
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
