Another part axed. :-( (limited stock available)
DSSA
Supporting Vendor
724
679
Jul 26, 2002
Hatfield, Pennsylvania
****************************THESE HAVE ALL BEEN SOLD****************************************
We try to keep on top of discontinued parts as it's getting more and more common these days, and try to keep you informed.
The MB526956 bearing kits ( https://jnztuning.com/product/oem-bearing-kit-driver-axle-awd-dsm/ ) are now discontinued.
These are the rebuild kits for the front, driver's side axle carrier bearings on all 1G/2G AWDs, Galant VR4s, and 1.6 Turbo Mirages. This does *NOT* replace the bracket itself (not included) , but allows you to rebuild it.
We have 4 (EDIT: Now 0 remaining) remaining in stock available. We'll only sell one per order as in the past we've had other people/businesses try to buy them and then resell them for crazy markup.
As always, we'll try to remove these from the site once they're spoken for, but in case we get they typical "run" on these parts, any additional sales over inventory stocks that are sold will be immediately refunded with apologies.
We have 4 remaining in stock available. We'll only sell one per order as in the past we've had other people/businesses try to buy them and then resell them for crazy markup.
Very noble of you, trying to prevent others from gouging the community. Especially when it would be easier and cheaper for you to just sell them all to one customer. 🤜🤛
Do you have the bearing number for this? That would be good info to have. It has to be off the shelf I would think.
I do not. The two in stock are already packaged to go out. The other two arriving tomorrow, I'll dig into before shipping.
Good call!
My notes from this kit were:
  • Small Seal - NOK BD2497H
  • Large Seal - NOK BD3209F, other marking includes 17
  • Bearing - NTN 6206LUA, other markings include NU TMB206V1 Japan 15C-1 110907 1016, measured at 62mm OD, 30mm case ID, 16mm thick, sealed bearing.
Then there's a small circlip / ring and a cap. But I don't have much on those that's helpful.
So it this a common replacement item and if so when, typically, mileage-wise?
It is a bearing that seems to have little load to deal with. No static weight, like a wheel bearing would. Likely not much thrust, either, since the c.v. Joints can move axially. Likely a seal failure is the biggest threat, and not “wear” per se.
Just an FYI to Tuners, I ordered a MB526956 kit from Japan and the order showed as in stock and is on the way. Gosh Mitsubishi is weird.
That just means they had a dealer or warehouse over there that had some remaining stock.
I know 1 of the seals cross over as an axle seal from a ford/ Mazda car think I was a protégé.
Bearing is easy to get, I couldn't find 1 seal tho but with Brian posting the part numbers from ntn that helps big time.
I've come across several parts that are discountinued or highly priced at suppliers on ebay right from Japan for cheap. Like 1g driveshaft carrier bearings in oem mitsu packaging for $80 each +shipping.....they sold out now but I think a supplier found the ebay listing and bought all the remaining supply a awhile back to sell them for $250 each etc. Just glad I got 6 before that happened.
Same thing happened when I found yoke kits for $50 each....... suddenly a supply of 100 gone in days.
Searching part numbers really helps find the deals.
What is the OEM part number for the bracket itself?
The brackets are not available separately, only as part of a kit. Kit part numbers are below.
1G auto - MB620417
1G manual - MB526981
2Ga auto - MB620417
2Ga manual - MB526981
2Gb auto - MR276642
2Gb manual - MR276643
1G auto - MB620417 (Currently 0 U.S. Stock)
1G manual - MB526981 (Currently 0 U.S. Stock)
2Ga auto - MB620417 (Currently 0 U.S. Stock)
2Ga manual - MB526981 (Currently 0 U.S. Stock)
2Gb auto - MR276642 (Discontinued)
2Gb manual - MR276643 (Discontinued)
Updated with U.S. inventory available.
