NWHTanK
- 1,521
- 528
- Apr 23, 2011
Odessa,
Missouri
Car overheard when it wants to , even with fans on full. New oem items, thermostat,radiator cap,water pump. After market items hoses misimoto rad and fans. Fan relay mod. 50 50 mix. Vacume filled. New belts. Muti layer head gasket with arp headstuds and retouqed. Compresion checks out fine. The antifreeze gets Brown is and I'm getting a Brown sediment that is very thick in the bottom of the over flow bottle, also metal filings on the radiator drain plug. I was thinking it has a stop leak of sorts that refuses to flush out . Some one mentioned a faulty ofh. Is their way to check ofh for this kind of failure. Oh and the oil is clean and full .
