marcelo_caz
- 185
- 0
- Dec 9, 2007
Beaverton,
Oregon
So, i've been looking on the forum for a while and still couldn't find an answer for my situation, so here it goes.
Yesturday I took my car to english racing for them to install my GM MAF-T, mine 3.5" intake pipe and tune the car.
Everything went well... intallation was really good and I got the car tuned at 15psi (peaks at 17psi).
I do have the 450cc, 14b turbo, and non-eprom ECU.
After talking to Lucas he told me to get the 580cc injectors so in the future to pump my boost up to 20psi (but I think he doesn't know I still have the non-eprom ecu.)
When I left his shop, the car was a beast, pulling really hard and holding 15psi at boost with no problem, but when I go from a dead stop and launch the car, I get fuel cut, my boost goes to 15psi, but the car doesn't pull.
Basecaly from a rolling start, I get that 15psi with no problem... pulls really hard, but from a dead stop I get fuel cut.
What should I do?
Will just the 580cc injectors take care of this? or would I need an EPROM ECU so I can get an eprom with no fuel cut?
Yes all the manitance on the car is done, there are no boost leaks or anything.. car is runing awsome, and I know that the stock 1G if you go over 15psi the ECU will cut my fuel.
But what can do???
Thanks for any help guys.
What should I do?
But what can do???
