shuedaman
- 56
- 1
- Aug 2, 2004
Hudson,
New Hampshire
After reading previous posts about smoking exhausts i've completed a test drive and a compression test (128, 145, 135, 141). There was quite a bit of oil on valve cover and car smokes when accelerator is smashed and for a few seconds after, but not on start up or at idle. Problem started happening right after i just finished installing new mods: supra sidemount, MBC, Upper IC pipe. Car has power, holds 14psi fine, no issues except the smoke. i have driven it VERY little because of the smoking, so i can't tell if the oil has become brown and i don't yet see any oil in coolant. Also, i do NOT know if the smoke is blue or white, too hard to tell. Any suggestions on next diagnosis step or what the problem is? Any help would be much appreciated!
) Especially if the smoke is whitish-gray, it's possible that the turbo's seals and bearings are shot, which leaks oil into the lower intercooler pipe and gets into the engine. Don't ask me why it burns whitish and not blue like oil is supposed to; I just know that in the case of a blown turbo, the smoke is white. Recently I read another post on here, possibly by a wiseman, that to truly rule out shaft play in the turbo, it's a good idea to check the hot side and see if there's play on the turbine side, but that's a little more involved than checking it from the intake side.
). Try to wiggle it up and down, side to side, and in and out. Any in and out play will most likely mean you need a new turbo. Very little side to side play is allowable, but if the blades touch the compressor housing (which can cause the whining noise Eastwood95 mentioned, and can also make a scraping noise when the car is turned off as the wheel spins down) then the turbo definitely needs replacing. To verify seals going bad, remove the lower intercooler pipe/hose and look for oil; a coating of oil on the inside of the intercooler pipe is okay since it probably came from the valve cover hose, but a pool of oil at the bottom of the hose or in the intercooler is definitely indicative of turbo failure.
