Please Support Kiggly Racing
Please Support Rix Racing
Another Bling*Bling Thread: Heat Shield & Exhaust
BacknBlack92ESi
2,340
Feb 19, 2003
Kansas City, Missouri
Today at work it was really slow. I had my heat shield off. I had intentions of pollishing it. So this as a good time. It took a total of about 5 hours to do all together.
The steps I used.
First Coat of Snap On Metal Pollish
1500 Grit Wet Sand- Took couple of hours
Pollish more
Wet Sand
More pollish
Repeated process dozen couple times
Steel Wool
Pollish again
Wet Sand
Final Pollish
I also did a quick sanding and pollish of the letters. I am going to be painting the Vavle Cover black with pollished letters this weekend
The process of the exhaust piping only took about 25-20 minutes since I only used a 800grit sand paper and pollished it 3 times.
Here you can see the difference from orginal Alluminized Piping to Blinged Out Alluminized Piping
End :cool:
Man, you need to do a DIY, you have a talent for this...
I was going to d one last night. But I ended up falling alseep. When I get off work today I will make one for the Heat Shield and the Exhaust.
And Defiant. Here at my work we have a heat protection coating stuff we use on the inside of fender wells on the 05' F-150's. I was going to use some of that for the underside.
